You are looking at the HTML representation of the WDDX format.
HTML is good for debugging, but is unsuitable for application use.
Specify the format parameter to change the output format.
To see the non HTML representation of the WDDX format, set format=wddx.
See the complete documentation, or API help for more information.
<wddxPacket version="1.0">
 <header/>
 <data>
    <struct>
      <var name="query">
        <struct>
          <var name="namespaces">
            <struct>
              <var name="-2">
                <struct>
                  <var name="id">
                    <number>-2</number>
                  </var>
                  <var name="case">
                    <string>first-letter</string>
                  </var>
                  <var name="*">
                    <string>Медиа</string>
                  </var>
                  <var name="canonical">
                    <string>Media</string>
                  </var>
                </struct>
              </var>
              <var name="-1">
                <struct>
                  <var name="id">
                    <number>-1</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Служебная</string>
                  </var>
                    <string>Special</string>
                  </var>
                </struct>
              </var>
              <var name="0">
                <struct>
                  <var name="id">
                    <number>0</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string />
                  </var>
                  <var name="content">
                    <string />
                  </var>
                </struct>
              </var>
              <var name="1">
                <struct>
                  <var name="id">
                    <number>1</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение</string>
                  </var>
                  <var name="subpages">
                    <string />
                  </var>
                    <string>Talk</string>
                  </var>
                </struct>
              </var>
              <var name="2">
                <struct>
                  <var name="id">
                    <number>2</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Участник</string>
                  </var>
                    <string />
                  </var>
                    <string>User</string>
                  </var>
                </struct>
              </var>
              <var name="3">
                <struct>
                  <var name="id">
                    <number>3</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение участника</string>
                  </var>
                    <string />
                  </var>
                    <string>User talk</string>
                  </var>
                </struct>
              </var>
              <var name="4">
                <struct>
                  <var name="id">
                    <number>4</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>OUT-CLUB.RU F.A.Q.</string>
                  </var>
                    <string />
                  </var>
                    <string>Project</string>
                  </var>
                </struct>
              </var>
              <var name="5">
                <struct>
                  <var name="id">
                    <number>5</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение OUT-CLUB.RU F.A.Q.</string>
                  </var>
                    <string />
                  </var>
                    <string>Project talk</string>
                  </var>
                </struct>
              </var>
              <var name="6">
                <struct>
                  <var name="id">
                    <number>6</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Файл</string>
                  </var>
                    <string>File</string>
                  </var>
                </struct>
              </var>
              <var name="7">
                <struct>
                  <var name="id">
                    <number>7</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение файла</string>
                  </var>
                    <string />
                  </var>
                    <string>File talk</string>
                  </var>
                </struct>
              </var>
              <var name="8">
                <struct>
                  <var name="id">
                    <number>8</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>MediaWiki</string>
                  </var>
                    <string />
                  </var>
                  </var>
                </struct>
              </var>
              <var name="9">
                <struct>
                  <var name="id">
                    <number>9</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение MediaWiki</string>
                  </var>
                    <string />
                  </var>
                    <string>MediaWiki talk</string>
                  </var>
                </struct>
              </var>
              <var name="10">
                <struct>
                  <var name="id">
                    <number>10</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Шаблон</string>
                  </var>
                    <string>Template</string>
                  </var>
                </struct>
              </var>
              <var name="11">
                <struct>
                  <var name="id">
                    <number>11</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение шаблона</string>
                  </var>
                    <string />
                  </var>
                    <string>Template talk</string>
                  </var>
                </struct>
              </var>
              <var name="12">
                <struct>
                  <var name="id">
                    <number>12</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Справка</string>
                  </var>
                    <string />
                  </var>
                    <string>Help</string>
                  </var>
                </struct>
              </var>
              <var name="13">
                <struct>
                  <var name="id">
                    <number>13</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение справки</string>
                  </var>
                    <string />
                  </var>
                    <string>Help talk</string>
                  </var>
                </struct>
              </var>
              <var name="14">
                <struct>
                  <var name="id">
                    <number>14</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Категория</string>
                  </var>
                    <string>Category</string>
                  </var>
                </struct>
              </var>
              <var name="15">
                <struct>
                  <var name="id">
                    <number>15</number>
                  </var>
                  <var name="case">
                  </var>
                  <var name="*">
                    <string>Обсуждение категории</string>
                  </var>
                    <string />
                  </var>
                    <string>Category talk</string>
                  </var>
                </struct>
              </var>
            </struct>
          </var>
        </struct>
      </var>
    </struct>
 </data>
</wddxPacket>
